Volvo Penta AQ170c
marco555
Volvo Penta AQ170c
Inlägg av marco555 » 07 jul 2019, 15:12
Hello everybody,
I am new here so I wil indroduce myself.
My name is Marco, 45 years old from the Netherlands.
I don't own a Fjord but a Fairline 32 flybridge sedan.
The reason I joint here is that I have a problem with the starboard engine of my boat,
It's fittet with 2 Volvo Penta AQ170c engines witch also common installed where in the Fjord.
The engine has underpressure in the oilsump so I think te pistonrings are worn, the engine needs overhauling and I am in search for a good adress for parts.
Here in the Netherlands isn't much availeble so I hope to find a good adress in Sweden.
2 new engines is of course an option but I like to keep the boat original and I like the engines very much.
If this is not allowed here then my excuses in advantage
Greetings,
Marco
Re: Volvo Penta AQ170c
Inlägg av Lars Lundbladh » 08 jul 2019, 16:29
Hi Marco
Welcome to Fjordclub forum
If you need help finding parts I can probably help you, here is some good links to suppliers for AQ170 or B30 as it was named in volvo Cars (164)
https://drevdelar.se/motordelar-bensin- ... vlager/b30
http://crommarine.bai.se/default.asp?sP ... sp?lId=349&
Look also for Volvo parts model 164;
https://www.cvi-automotive.se/
http://www.vp-autoparts.com
marco555
Inlägg av marco555 » 08 jul 2019, 18:01
Thank you verry much Lars!
I've bin told that the B30 engine has some different internal parts in compare to the AQ170 such as crankshaft bearings and so.
I'm gonna brouse those websites.
Inlägg av Lars Lundbladh » 08 jul 2019, 19:00
There are differences but mor related to the cooling system. I the motor has freshwater cooling with heat exchanger The cylinder head on some models have different sized valves.
You might also look here
https://shopcdn.textalk.se/shop/31500/a ... 1vp170.pdf
Inlägg av Lars Lundbladh » 08 jul 2019, 19:10
Here is a picture of me and a renovated AQ170 :)
Inlägg av Lars Lundbladh » 08 jul 2019, 19:11
<iframe src="https://drive.google.com/file/d/1FLvHso ... wv/preview" width="640" height="480"></iframe>
Inlägg av Lars Lundbladh » 08 jul 2019, 19:12
https://drive.google.com/file/d/1FLvHso ... UKXwv/view
