English manual for Fjord 24 Attache
Jivin John
Inlägg av Jivin John »
Hi all,
I have Justin purchased a1979 Fjord 24 Attache, unfortunately no manuals or technical information was supplied. I'm told the engine is 2.5 ltd diesel delivering 100hp, I think it's a Volvo Penta.could you tell me where I may be able to get English manuals for the boat and also for the engine. The drive to the propeller is via a Z drive so I believe I have the ability to be able to raise it using the switch in the cockpit, is this correct, do I need to decouple anything first? I have many more questions which I hope the manual will answer especially around the electrics and circuit diagrams.
Many thanks
John C
Re: English manual for Fjord 24 Attache
Do you have any identification or pictures on the engine? Could be an Volvo Penta MD21/29, AQAD30 AQAD31 or other?
Manual for the engine is available/downloadable from Volvo Penta :
https://www.volvopenta.com/marineleisur ... books.html
Search on Product Designation (engin type)
You can tilt up the stern-drive with buttons from the cockpit if you have power trim you can drive with the boat in an raised position. I you have only tilt version you can only rise the drive in neutral gear. So it depends what type you have powertrim is always hydraulic type.
The manual and electrical circuit diagram see e-mail.
