Hello with all,
I have a question which annoys me since can and which I wish to solve.
I changed my propellers (Fjord Weekender 24) according to the councils of Lars Lundbladh who advised me 15x17 and I must say here large a thank you to Lars because the output and the nervousness of the boat are clearly improved. Thank you Lars.
On the other hand, by changing the propellers, there is of them one which turned freely to the hand in the 2 directions whereas the other turned only in one direction and was blocked in the other direction. In addition, of this there with dimensions, when I go into reverse, the sterndrive one is raised and that frightens me. Could you indicate the place of the problem to me and how to solve it.
Large a thank you with all.
In waiting.
Better friendly greetings.
Marcel
Problem on Sterndrive
Dear Marcel
You have problems with the reverse tilt lock. Usually this is jammed because of paint or grooving of algae’s
Read more how to solve and adjust this here:
http://www.marinemechanic.com/volvo/tilt_lock_1.htm
